Blinkers will not work
JAMES ROBERT LONG
  • 2003 CHEVROLET MALIBU
  • 3.1L
  • V6
  • FWD
  • 132,000 MILES
Turn signal does not work when I put on the blinker on. I have replaced the turn signal switch and still no blinker.
Saturday, October 6th, 2018 AT 4:13 PM (Merged)
HMAC300
  • 48,601 POSTS
The blinker is part of the hazard switch, see if it gives power in and out. So even if hazards work and turn signals do not then you have to replace the hazard switch.
BURRJE
  • 2001 CHEVROLET MALIBU
  • 3.1L
  • 6 CYL
  • FWD
  • 154,000 MILES
So I have no blinkers at all not inside or out and everybody's sad the problem is the hazard light I fixed that still nothing then changed the whole blinker lever still nothing and I've checked all the fuses and still nothing
HMAC300
  • 48,601 POSTS
If you didn't change the hazard light switch the blinker is in that.
MICHAEL H. ASBURY
  • 6 CYL
  • AWD
  • 175,000 MILES
I replaced the driver side turn signal bulb on the front of the car as well as the turn signal bulb on the back of the car. My issue is that the drivers side front turn signal bulb is clicking rapidly fast an the driver side turn signal bulb in the back is not flashing at all and they are both new bulbs. So I know it is not a bad bulb. Any help would be appreciated thanks.
STEVE W.
  • 13,628 POSTS
Most likely issue would be the circuit plate that the bulbs plug into. Either the contact(s) for the bulb have failed or the circuit inside that connects the lamp to the connector pin has failed. Then there is the actual connector that hooks the plate to the wiring in the car.
test the harness connector first. If it tests okay just replace the socket plate itself.
Get a simple test light.
Unplug the harness connector. If you look at the connector there will be a black wire which is ground and a light blue with black stripe wire which is your turn signal. There will also be a brown wire which is the marker light. Take the test light and connect it to a good ground. Now turn on the headlights and touch the contact for the brown wire. The light should light up if you have a good ground. Now turn on the turn signal and touch the contact for the light blue with black wire. It should flash the light. If it does replace the circuit board assembly.
If it does not then you need to test that wire where it connects to the fuse panel at the right end of the dash. It may have broken in between. But I will bet it is the plate.
KATHERINE CLINE
  • CHEVROLET MALIBU
When the switch is on, the signal clicks rapidly, but the signal light does not flash. What needs to be done to remedy this?
CHEVY22
  • 1,375 POSTS
Do you mean when you use the turn signal the dash light blinks fast but the outside light does not?
If so you have a bulb out if not let me know
KATHERINE CLINE
The dash light does not flash, only the clicking sound, more rapid than normal. The Malibu is a 2000. Is this caused by the rear turn signal lights being out, or are all four lights bad?
CHEVY22
  • 1,375 POSTS
If you have any bulbs that are known bad replace them first, then recheck and let us know
KATHERINE CLINE
Okay. Will replace rear bulbs and let you know the results.
KATHERINE CLINE
You're going to love this: the bulbs are okay. The turn signals are okay. The hazard light button sometimes doesn't completely turn loose when it is turned off, and that will cause the turn signals to do what mine were doing.
Remedy: press hazard lights botton on and then off. Presto! The turn signals work perfecly.
I'd love to claim it, but it was shown to me by the helpful man at Advance Auto.
Thanks for your time & have a great day. I'm signing off.
DAVIDSTROK
  • 6 CYL
  • FWD
  • 85,000 MILES
Hello 2carpros, my turn signals just started acting up. Most of the time they don't work. Then the next minute all is fine. The hazards mostly don't work, they try to come on once. Then nothing. What could be wrong? Respectfully, David Strok
CHEVY22
  • 1,375 POSTS
Too funny
thanks
jim
DOCFIXIT
  • 18,828 POSTS
Most likely turn signal multifunction switch faulty
GMTECH
  • 537 POSTS
Actually most likely it is the hazard switch which has the flasher built into it. Check with the dealership on this one as it might be covered by a special recall.
SHOLMES27
  • 2002 CHEVROLET MALIBU
  • 6 CYL
  • 124,000 MILES
Doesn't work
Saturday, October 6th, 2018 AT 4:14 PM (Merged)
JOHN_35120
  • 12 POSTS
The relaly that works your turn and emer is in your emer flasher. Replace your emer switch.
