What would cause my Audi to all of sudden die while i was driving it? After it stopped running i try to turn it over and it acts like the starter is not engaging. I noticed an aluminum pipe thats about 1/2 inch to 3/4 inch in diameter that had been broken in the central passenger side almost directly under tha radiator.........There are two of these pipes/tubes that run paralell to eachother running from passenger side to the center. Could these be a type of vacuum tubing that activates the starter or keeps the motor running?
Thank You So Much
Sincerely
Colton Belliston
Thank You So Much
Sincerely
Colton Belliston
Oct 23, 2008 at 7:42 AM
