Incorrect timing, loud compression noise was made when starting the car. Car will not start
209,000 MILES • 2.4L • V6 • MANUAL
REEBABII
A very Loud compression noise was made when starting the car after touching the timing belt? The car will not start now. The thermostat housing was replaced but I think the timing was incorrect. Can anyone suggest ANY PROBLEMS THAT MAY HAVE CAUSED THIS?
Dec 17, 2013 at 7:09 PM
  • 110,251 POSTS
Was the timing out?
Dec 17, 2013 at 10:49 PM
EXOVCDS
  • 1,882 POSTS
If the timing belt was taken off, tools were required to set cam & crank
timing, as well as a puller to free the cam sprockets so that they can
spin freely for timing belt placement & tensioning.
If none of that was done, engine damage may have occurred.
2.4l V6? Not a 2.8l V6? Where are you located?
Thomas
Dec 28, 2013 at 2:29 PM
