1993 Suzuki Swift No Spark
Suggested Repair
Install the correct ECM/ECU for this 1993 Suzuki Swift 1.3; several ECUs exist and a used unit with different part numbers will not restore spark. Code 41 means no distributor signal. Also confirm pickup air gap (about 0.008 in), coil and pickup resistance, fuses, and ignition-switch power before replacing other parts.
Conversation Summary
A 1993 Suzuki Swift 1.3 had no spark while cranking, though the fuel pump primed and dash lights worked. A new igniter, good fuses, normal coil and pickup resistance, and a moving distributor rotor did not restore spark. Key-on distributor voltage matched the manual (about 0.04-0.08V), not 12V. Code 41 indicated no distributor signal. A used computer with different numbers also failed. An expert suspected the processor, and another owner reported the same no-spark problem was fixed only after installing the correct ECU.
