1993 Toyota Camry No Spark No Start
Disconnect one spark plug wire and crank it over while looking for spark.
Do you hear the pump humming underneath for 2sec's
Also check the EFI fuse
If you have it at the coil and not on the plug end, change the cap and rotor its no good. If you don't have it at the coil-check for power at the positive terminal, power there its the Ignitor. you need to change the whole distributor assembly.
First, if you have no spark, check the connectors on the distrubuter for loosness or corrosion.
Check power supply to the ignition coil. Turn on the ignition switch, and check if there is battery voltage at the ignition coil (+) terminal. If not, suspect ignition switch. If good voltage, check the resistance of the ignition coil. Resistance cold should be Primary 0.4-0.5 ohms and secondary 10.2-14.3 ohms. If good check resistance of the signal generator pickup coil. resistance cold should be G+ and G- 185-265 ohms NE+ and NE- 370-530 ohms.
If this is good check for air gap of the distributor. should be 0.2-0.4mm (0.008-0.016 in).
If that is good, check IGT signal from ECU.
Judging by the symptoms, it does sound like a bad coil, but its always best to trouble shoot.
Looks like it is mounted to the left fender well with a plug on the top. Here is a resistance check to test the coil.
Inspect Primary Coil Resistance
Using an ohmmeter. measure the resistance between the positive (+) and negative (-) terminals.
Primary resistance: 0.21 - 0.32 ohms
If the resistance is not as specified. replace the ignition coil.
Checking Secondary Resistance
Inspect Secondary Coil Resistance
Using an ohmmeter. measure the resistance between the positive (+) and high-tension terminals.
Secondary resistance: 6.4 - 10.7 k ohms
Suggested Repair
Confirm no spark at the coil and plug wires, then check distributor connectors, battery voltage at the coil positive terminal, coil and pickup-coil resistance, distributor air gap, and the IGT signal before replacing parts. Also verify the EFI fuse and a brief fuel-pump hum. The coil is described as mounted on the left fender well; replace the coil, ignitor, or distributor only if those checks fail.
Conversation Summary
A 1993 Toyota Camry V6 died while accelerating and then cranked without firing. The owner found no spark and good-looking fuses and asked whether the fuel pump or ignition was at fault. Experts advised checking spark at the coil and plug end, listening for a two-second fuel-pump hum, and inspecting the EFI fuse. Further guidance covered distributor connector condition, coil power and resistance, pickup-coil resistance, distributor air gap, and the ECU IGT signal. The coil was identified on the left fender well, but no repair was confirmed.
