1993 Toyota Camry 4 cyl Two Wheel Drive Manual
HI!
I AM MECH STUDENT. MY CAR STOPPED WHILE RUNNING.
I CHECKED FUEL PUMP, BATTERY AND IGNITION MOTOR EVERYTHING IS GOOD. LEADS HAVING 14-16 OMS RESISTANCE. THEN I TOOK OUT A SPARK PLUG AND CRANKED THE ENGINE NO SPARK IS BEEN PRODUCED. I CHECKED THE IGNITION MODULE IS ALSO GOOD. THEN I GOT A SECOND HAND DISTRIBUTOR SAME PROBLEM OCCURS, I CHECKED THE INSIDE AND OUTSIDE LINKS OF THE DISTRIBUTOR CAP IT SHOWS 0 OMS.
WHAT COULD BE THE PROBLEM OF SPARK NOT GENERATING?
HOW SHOULD I CHECK THE DISTRIBUTOR?
PLEASE HELP!
KIND REGARDS,
TAHIDUL
SPONSORED LINKS
Thursday, July 15th, 2010 AT 1:20 AM
