1993 Toyota Camry 1993 Camry wont start
SURPERA1
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 200,000 MILES
Just died on me coming home from work one night - installed new plugs, wires, distributor cap, rotor, fuel filter, pcv valve, fuel pump, and fuel pressure regulator - no power to fuel pump when ignition switch on - I jumped power to the fuel pump and forced it to power on for a while - still wont fire up - turns over normally - first EFI relay checks fine - when I jump the contacts it engages the circuit opening relay - I can hear it clicking - can get my fingers on it behind the glove compartment - but havent been able to get it out yet - I am really stumped here - I am not a mechanic per se - but I was an electronics tech for like 14 years - any ideas? Thanks so much in advance !
Friday, September 24th, 2010 AT 10:44 AM
In the airflow meter block wide open the vane flap and attempt to start let me know
Friday, September 24th, 2010 AT 10:53 AM
SURPERA1
Ok - still wont start
Friday, September 24th, 2010 AT 11:25 AM
SURPERA1
Ok - still wont start[/quote:bc3ab245c1]
did hear the circuit opening relay engage and fuel pump engage
Friday, September 24th, 2010 AT 11:32 AM
In the check connector in engine compartment jumper the Fp to Batt this will power the pump if not check and test the EFI relay and the Circuit opening relay-also check the EFI fuse-BTW are you getting spark
Friday, September 24th, 2010 AT 4:00 PM
SURPERA1
Not getting spark - stuck a screwdriver in a plug wire - held it up to the motor - turned it over - pulled distributor cap off - made sure rotor was turning - it was
Saturday, September 25th, 2010 AT 10:32 AM
SURPERA1
Not getting spark - stuck a screwdriver in a plug wire - held it up to the motor - turned it over - pulled distributor cap off - made sure rotor was turning - it was[/quote:f3636864f5]
did voltage checks at connector to distributor - not seeing 12 VDC with ignition switched on
Saturday, September 25th, 2010 AT 12:24 PM
