1993 Toyota Camry wont start
RJTURNERR
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 130,000 MILES
Well this is driving me nuts your turn
engine has compression rotates correctly is in time getting fuel but has no spark drove to a friends shut it off wouldnt start back up replaced coil replaced ignitor
plugs were burnt so new plugs even replaced the distributor but still no fire no spark any ideas
Thursday, September 11th, 2008 AT 12:54 PM
Check igntion fuse and test for power at the coil positive terminal. If both okay-could be a problem with the computer not telling the ignitor to fire the coil thru the Igt signal wire.
Thursday, September 11th, 2008 AT 3:09 PM
DOCFIXIT
  • 18,828 POSTS
Take off distributor cap observe while cranking does it move? If not timming belt let go.
Thursday, September 11th, 2008 AT 3:29 PM
While cranking the engine over check the white wire at the ignitor if its getting signal from the computer Igt signal.
Also Mr. Docfix could be right on the T/belt if the rotor is not spinning or the distributor drive gear sheared off
Thursday, September 11th, 2008 AT 4:29 PM
