Why is my carburetor not getting any fuel?
140,000 MILES
CADIEMAN
  • 3,544 POSTS
replace the pump and filters.
Apr 5, 2012 at 9:50 AM
  • 30,869 POSTS
Before replacing the fuel pump and filters there could be clogged pick up in the tank causing thr fuel pump to not get fuel to pump.Or a issue with the carb float not allowing fuel into the carb?The first thing you have to check is if your getting fuel to the pump?Not just lets throw parts at it and see what sticks.
Apr 5, 2012 at 9:57 AM
RESTOREMAN
sounds to me like the problem is coming from the fuel tank ,maybe the sending unit or float in tank hope this helps
Aug 9, 2017 at 7:51 AM
  • 30,869 POSTS
The sending unit and float tells how much gas there is it doesn't effect the flow of gas.The pick up with the sock on the end of the pick tube effect the flow of fuel.
Aug 13, 2017 at 12:42 AM
