Before replacing the fuel pump and filters there could be clogged pick up in the tank causing thr fuel pump to not get fuel to pump. Or a issue with the carb float not allowing fuel into the carb?The first thing you have to check is if your getting fuel to the pump?Not just lets throw parts at it and see what sticks.
SPONSORED LINKS
Thursday, April 5th, 2012 AT 4:57 PM
