How to Repair Power Steering Problems
A power steering system is designed to utilize power from the engine or an electric motor to assist in the force needed to steer a vehicle which is achieved by a steering box or rack. EV's will have an electric steering rack that may or may not be attached to the steering wheel, a sensor and control unit give the steering rack commands via the position of the steering wheel. We will address hydraulic based systems first and then move onto electrically assisted systems.
What Goes Wrong?
There is a fair amount of force involved when steering a vehicle, an electrical motor or a hydraulic assist system can wear or fail completely creating a difficult situation when controlling the car. This can be due to a fluid leak, pump or electric motor failure which typically is accompanied by an abnormal noise. It is advised NOT to move a vehicle with the power steering system not operating or the engine not running, you may lose control of the vehicle. Sometimes the steering system is not the problem, if you lose power steering and the battery warning light comes on it means the serpentine belt of the engine has fallen off.
Let's Jump In!
When steering your vehicle, if there is a low grinding or gurgling sound the first inspection is to check the power steering fluid level, if the fluid is low the pump will be weak and make noise as it scavenges for fluid. Check the power steering fluid level by locating the power steering fluid reservoir and removing the cap (twist counter clockwise). Some systems have a fluid level dipstick mounted inside the cap while others are present on the side of the fluid reservoir, if the fluid level is down or empty the system has a leak. Using a flashlight the system should be inspected for leaks.
adding power steering fluid
A popular failure for power steering system leaks and non operation is the high side power steering hose, use a flashlight to inspect the hose, the failure will be obvious, if leaking or blown the steering hose will need to be replaced.
new steering hose
If the the system is full and the belt is on the pump but it still has no power steering chances are there is no pressure being produced and the power steering pump needs to be replaced.
new power steering pump
If your car has power steering in one direction but not the other this means the power steering rack and pinion, or steering box needs to be replaced.
new power steering box
EV's and some conventional gasoline vehicles are equipped with an electronic steering system which can be assisted with an electrical motor or completely electrical (no shaft connecting the steering wheel to the rack). In either case, the system can malfunction due to a blown fuse, sensor or main controller failure, or electrical motor can wear or short out completely. If a failure occurs and the fuses are okay, a regular code scan will be needed. If no codes are present a more in-depth CAN scan (controller area network) to identify the problem. Below is an example of what an electric steering rack looks like.
electric rack and pinion
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
