wont start and cannot put into any gear
220,000 MILES • 3.2L • 6 CYL • FWD • AUTOMATIC
DARRYL DWIGHT TURKEY
wont start the battery is newer. all other systems come on lights radio etc., wont turn over plus with any vehicle I can put a car into gear if I need to push it or tow and it wont let me even shift.
Dec 17, 2016 at 7:03 AM
HMAC300
  • 48,601 POSTS
try resetting security system, see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 18, 2016 at 12:33 AM
STEVE W.
  • 15,420 POSTS
In most newer vehicles with automatics there are shift interlocks that will prevent you from moving the shifter unless you have a good battery and step on the brake first.
If the vehicle has a security system and the key is the wrong one or cannot be read, it will not allow the interlock to release as well. That is to prevent a thief from just shifting into neutral and towing the car to a better location.
Try the reset above. If it does not work, and you have tried all the keys you have and none work. It could be a failed key reader, failed control module or bad wiring.
Dec 18, 2016 at 2:15 AM
