Will not start again after warmed up
202,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JDEMING
Car starts and runs fine. Then once warmed up,if you shut it off, it just turns over acting like it gets no fuel or no spark. Dealership has changed battery, fuel pump and ignition. Still does the same thing. If you let it sit, it will start the next day.
Aug 24, 2019 at 10:49 AM
Good morning,
When it will not start, you need to check for spark and fuel.
Fuel pressure needs to be checked. When it does not start, spray some carburetor cleaner into the air filter and see if it starts and stalls.
Spark needs to be checked. If it has no spark, could be a module, coil pack or a crank sensor.
Aug 25, 2019 at 2:40 AM
99BONNIE
Had the same problem it was my fuel pressure regulator, basically it’s “hydro locked” in a sense. Hope this helps.
Dec 10, 2019 at 11:41 AM
Thanks for the information.
Dec 10, 2019 at 11:44 AM
