Won't start
156,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
COPPINGER1987
We have checked the fuses, changed the battery, chedcked the alternator, and we have spark and gas going to the engine but will not start. We also do not have power windows, power seats, or mirrors but did before. We have no idea what else it could be.
Sep 4, 2016 at 10:01 AM
DOCFIXIT
  • 18,828 POSTS
What model? How was spark and fuel delivery confirmed ? Do you have a meter to test for voltage? Does started engage and engine spin ? Did problem occur suddenly ? Any recent repairs?
Sep 5, 2016 at 3:12 AM
COPPINGER1987
Its a 99 Pontiac Bonneville 3800 spark was tested by taking spark plugs against metal to see and fuel was checked by checking fuel line valve no we sdo not have a meter for voltage starter does engage and engine spins yes the problems happened all of a sudden and the only repairs where brake line and new battery we had alternator checked and it came back as good the weird part is when we turn thee steering wheel it starts sometimes until you touch the window switches
Sep 5, 2016 at 7:06 AM
DOCFIXIT
  • 18,828 POSTS
To resolve this problem it will need a trained technician to trouble shoot. Common charge is a two check out fee and hopefully will be able to provide a diagnosis. From what you have stated problem may be in ignition switch and /or the RAP module no way to say for certain until testing is done.
Sep 6, 2016 at 5:10 AM
