At fuel pump prime, key on engine off, is there fuel pressure, use a gage. After the initial prime, if no rpm signal, the relay won't energize, in my opinion. Can you check for codes? If no pressure at initial prime, I'd suspect the pump, I'd also need to check proper voltage and ground. I don't care if the pump is new.
Wednesday, December 16th, 2009 AT 12:21 PM
