1999 Pontiac Bonneville car wont start
DISCODADDY61
  • 1999 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 180,000 MILES
Engine wont turn over and I believe the battery is ok
Friday, May 15th, 2009 AT 9:15 PM
If you meant it will crank and will not start do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Friday, May 15th, 2009 AT 9:20 PM
