Engine will not crank over?
KAEWHITE
  • 7 POSTS
No sir, no overheating at all.
Thursday, August 6th, 2020 AT 10:16 AM (Merged)
KAEWHITE
  • 7 POSTS
Thank you very much I will be replacing this piece tomorrow. Only problem I ran into is the metal protective shield has been welded on. Any ideas to get it off?
  • 52,797 POSTS
Ok, do you have any way of checking for spark? Ignition module is a very common failure for this issue as well.
STEVE W.
  • 13,573 POSTS
Not really without seeing it. Don't know why it would be welded on though.
KAEWHITE
  • 7 POSTS
Hello Mr Steve I've replaced my starter and my alternator. It cranks but won't start I was being told my battery was good got it charged at autozone after the alternator was replaced. Then I learned today when I picked it up that it has a dead cell. I placed the battery from my trail blazer in it it still cranks but don't start. Any ideas?
STEVE W.
  • 13,573 POSTS
You need to discover what is missing, fuel or spark. A fast way to do that is to just spray a little starting fluid into the air intake while someone cranks the engine. If it tries to run you have a fuel issue. After that it's time to check for fuel pressure.
