After installing a new engine, it will not start?
110,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MORRISCOLIN24
  • 6 POSTS
I installed a brand-new motor. Everything back in all grounds are connected new battery, new starter motor and just clicks.
Nov 24, 2023 at 3:16 AM
CANNON1349
  • 861 POSTS
Hello and thanks for your question!
First of all, make sure the new motor has oil in it, and turn it over by hand and make sure there is not any unreasonable resistance.
Second, it is not uncommon for new starter motors to be duds. As simple as it can be, I would bench test the starter or just swap it out if you still have the receipt.
You mentioned grounds are good, but have you tried jumping the starter? Could be a loose hot wire instead of a ground.
Let us know
William
Nov 24, 2023 at 10:58 AM
MORRISCOLIN24
  • 6 POSTS
I took the relay and jumped it. It moved then stopped.
Nov 25, 2023 at 1:55 AM
CANNON1349
  • 861 POSTS
I know it's a tight fit, but can you jump the starter using only the connections at the starter motor?
And can you confirm the engine will at least turn?
At the moment I would try another starter, as it sounds like it could be a dud.
Let us know,
William
Nov 25, 2023 at 1:59 AM
MORRISCOLIN24
  • 6 POSTS
Starter working it’s turning the fly wheel and the motor can spin over by hand.
Nov 25, 2023 at 4:24 AM
MORRISCOLIN24
  • 6 POSTS
I got another starter and it’s still not starting.
Nov 27, 2023 at 5:40 AM
CANNON1349
  • 861 POSTS
Could you send us a video of what's going on?
Thanks,
William
Nov 27, 2023 at 5:54 AM
MORRISCOLIN24
  • 6 POSTS
Won’t send the video.
Nov 27, 2023 at 6:11 AM
MORRISCOLIN24
  • 6 POSTS
I figured it out I left a ground off the motor when I put it back together put the ground on and it fires right up.
Nov 29, 2023 at 4:20 AM
CANNON1349
  • 861 POSTS
Thanks for getting back to us. This is great news! Sometimes it's the small things in a big repair that give us the most headache.
Let us know if you need anything else,
William
Nov 29, 2023 at 4:25 AM
