The starter solenoid is not working, when ignition is moved to start, solenoid moves out to engage flywheel teeth and starter motor rotates to turn engine over.
Remove starter and take to most autoparts stores and have it bench tested for free. This will tell you if starter is bad.
Alternator would not have the symptoms you describe.
SPONSORED LINKS
Thursday, December 17th, 2009 AT 9:39 AM
