2000 Volkswagen Jetta Suspension Squeak
2000 VOLKSWAGEN
WINDRACERRR
I have a 2000 Jetta IV GSL 1.8T with 93,000. I have noticed an increasing squeaking sound coming from the suspension. It gets worse after driving a while and basically sounds like an old bed or screan door for lack of a better description. I am thinking that it is from the shocks but not sure. Are there grease fitting on this car or is that a thing of the past with newer cars?
Jun 6, 2007 at 5:25 AM
WINDRACERRR
I have a 2000 Jetta IV GLS 1.8T with 93,000 miles. I am having to add a couple of quarts of oil in between oil changes and am wondering if the head gasket needs replacing or is it a cylinder ring issue. There are no noticeable leaks but if I step on the gas there is noticeable smoke coming out the exhaust. It still gets good gas mileage and no other issues.
Jun 6, 2007 at 5:29 AM
2CARPRO JACK
  • 11,533 POSTS
Could be the turbo doing that. Your squeek, could be the sway bar, aside from that you will have to look for grease fittings, but dont think you will find any
Jun 6, 2007 at 7:52 AM
Suggested Repair
Inspect the sway bar for the suspension squeak; grease fittings are unlikely. Exhaust smoke and oil use with no external leaks may be the turbo rather than the head gasket or rings.
Conversation Summary
The owner of a 2000 Volkswagen Jetta reported a worsening suspension squeak and, separately, oil use between changes with exhaust smoke under acceleration and no visible leaks. The expert said the squeak could be the sway bar and grease fittings are unlikely, and that the smoke could be from the turbo.
