Possible CV Joint Replacement
VOLKSWAGEN
DUTTONMN
I have a 2004 VW JETTA with 34,000 miles on it. I just bought new tires less than 1,000 miles ago, had them balanced, and the works done to them.
I brought it back to sears where i had the tires installed, and had them re-balance them. Because they have said that with VW Tires, they are unable to put the standard car weights on the tires because of the design.
However, i was told by a colleague that it may be my cv joints. Because when i go around corners, or am driving at a high speed i have vibrations, and almost rubbing noises. Should i take it to a mechanic to have them investigate, or should i just go ahead and replace the cv joints myself.
My fiance is a mechanic in the Coast Guard, so i'm thinking that he migh be capable of doing this task. Please tell me if i'm way over my head.
Oct 15, 2007 at 6:22 AM
SERVICE WRITER
  • 9,123 POSTS
Call the dealer and see if you are still under factory warranty for that.
May be a bearing problem.
Oct 15, 2007 at 6:35 AM
DUTTONMN
You were right...it was in fact a bearing problem!
Oct 16, 2007 at 4:42 AM
SERVICE WRITER
  • 9,123 POSTS
Almost like I know what I'm doing :wink:
Oct 16, 2007 at 9:55 AM
