2007 Volkswagen Jetta Engine Whine
2007 VOLKSWAGEN
SMART3
I just purchased an 07 Jetta last week. It is a 2.5 5 cyl base model automatic with about 5600 miles. They said it was a loaner car. It is my first VW, so I hope I made a good decision. I have noticed a very high pitched whine (like a mosquito in your ear) from the engine upon accelerating. It goes away once it hits about 3rd or 4th gear. Any ideas? I'm hoping it is just the way this type of car sounds. Thank you.
Nov 26, 2007 at 10:42 AM
2CARPRO JACK
  • 11,533 POSTS
Manual trans? Does the noise stay the same regardless of engine rpm?
Nov 26, 2007 at 11:49 PM
SMART3
It is an automatic and the whine does seem to get a little higher upon acceleration, but like I said it goes away after it settles into 3rd or 4th gear. Thanks again!
Nov 27, 2007 at 3:48 AM
2CARPRO JACK
  • 11,533 POSTS
Try putting the car in neutral while it is making the noise......... see if it goes away or changes
Nov 27, 2007 at 3:55 AM
SMART3
It is not there while in neutral or while idling. It seems to only occur during acceleration in the lower gears.
Nov 27, 2007 at 1:57 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a trans problem. Might want to have a shop do a diagnostic before something big happens.
Nov 27, 2007 at 11:36 PM
Suggested Repair
Have a shop perform a transmission diagnostic before a larger failure occurs. The whine only during acceleration in lower gears, and not in neutral or at idle, points to a transmission issue.
Conversation Summary
The owner of a low-mileage 2007 Volkswagen Jetta 2.5 automatic reports a high-pitched engine whine during acceleration that disappears in 3rd or 4th gear. It is absent in neutral and at idle. The expert says it sounds like a transmission problem and recommends a shop diagnostic before something major happens.
