It was running great. While driving, thankfully almost
home, it started missing and hesitating. The engine
light came on. I got it to the driveway, and shut it off. Iit wouldn't start after. First thing I did was check the engine code.(341) It took me several days to find someone that could tell me that this car does not have a camshaft TDC sensor. And that it was the Hall's Effect sensor. But, being the sceptic.
I have great spark and the distributor and the spark
plugs? So, on vacation I ran into a guy who said that he specialized in foriegn cars. He said that if the speedometer was moving slightly when the car is turned over it was generally a indication of the Mass
Air sensor being bad? I had checked the fuel pump and filter? This is a sensor related gas shut off situation? I have great pressure to the gas regulator?
No gas is getting to the cylinder after the brain translates this problem. It almost starts the first time you turn it over then just turns over after that?
This is the 2.0 engine.
Any help would be appreciated.
Thanks
Thursday, April 24th, 2008 AT 9:13 AM
