1996 Volkswagen Golf Crank But Won't start
NELECZO
  • 1996 VOLKSWAGEN GOLF
  • 4 CYL
  • FWD
  • MANUAL
  • 105,000 MILES
1996 Volkswagen Golf gl 2.0 cranks but no spark
Put new ignition coil, disturbutor, cap, wire, spark plug. Have power to coil and disturbutor.
Any idea? I already donated
Thursday, January 31st, 2008 AT 6:29 PM
2CARPRO JACK
  • 11,533 POSTS
One of the posts on the coil should flash when the engine is cranked with a test light hooked to it. This tells if it sees the crank turning
Friday, February 1st, 2008 AT 11:30 AM
NELECZO
The post on the coil does not flash. Could it be the ECU?
Friday, February 1st, 2008 AT 1:15 PM
2CARPRO JACK
  • 11,533 POSTS
Maybe. Does it have compression? More likely the crank angle sensor or the cam angle sensor
Friday, February 1st, 2008 AT 2:55 PM
