2005 Vauxhall Corsa Diesel:Won't Start,Headlamps keep break
115,000 MILES • 4 CYL • 2WD • MANUAL
CHRISTOPHER20F
2005 Corsa Utility 1.7dti
My car struggled to start in the mornings,summer or winter,but once it started and drove it started immediately during the rest of the day.But lately when the car stays stationary for an hour or so is struggles to start,any time of day or season.
The other problem is i keep blowing front headlamps,never at the same time but i keep replacing headlamps every 2 to 4 months plus lately when i start the car one headlamp will stay of until the car starts moving and then goes on.Another thing is the odo meter sometimes stays off until you give it a light tap then it goes on.
Please help.
Christopher Francis
Oct 18, 2009 at 9:42 AM
DAVE H
  • 13,383 POSTS
replace the glow plugs .. and add a good fuel addative to the tank to clean the injectors .. the headlamp has a bad/loose wire somewhere !
Oct 20, 2009 at 8:07 PM
CHRISTOPHER20F
Thanks Dave...will keep you posted.Any Idea were to look for the loose wire in the headlamp? Would this cause both headlamps so blow every 2nd or 3rd month or so?
Oct 21, 2009 at 10:28 AM
