2003 Vauxhall Corsa car wont start
PAIGEHAY06
  • 2003 VAUXHALL CORSA
2003 Vauxhall Corsa Manual
got corsa c 53 plate.
car wont start.
had load of sensors changed, still no good.
machanic told me there is no spark or petrol getting to engine.
need help please
Thursday, February 25th, 2010 AT 6:47 PM
DAVE H
  • 13,384 POSTS
Have the vehicle plugged into a diagnostic computer. Repost with fault codes for more assistance
Friday, February 26th, 2010 AT 2:22 PM
PAIGEHAY06
Diagnostic told me it was unrecognised codes,
now starter motor been changed,
cam been done,
crankshaft sensor done,
coil pack changed
and spark plugs changed
ticking a lot from carburetor
engine managment light flickering continuesly.
Does start some times and runs ok when started but then will not start again.
Any ideas?
Sunday, March 7th, 2010 AT 10:48 AM
DAVE H
  • 13,384 POSTS
Could you please supply the code letter and numbers you got off the diagnostics scan ?? is the management light flickering or flashing on and off .. if it is flickering sounds like you have bad wiring connections to the PCM (computer)
let me know
https://www.2carpros.com/forum/automotive_pictures/266999_smiley3_20.png
Monday, March 8th, 2010 AT 3:44 AM
PAIGEHAY06
Flickering all the time when trying ignition.
You say this sounds like bad wirring connections to the pcm(computer).
Would this mean a new ecu?
Monday, March 8th, 2010 AT 8:00 AM
DAVE H
  • 13,384 POSTS
I really need the diagnostic codes to help further ! If the ECU (PCM) is supplying codes it may not be bad/faulty. It could be a loose/damaged wire or connector.
Wednesday, March 10th, 2010 AT 3:36 AM
Related Engine Not Running Content
Car Cranking but Not Starting? Try This
VIDEO
