1997 Vauxhall Corsa won't start, no fuel getting to carbere
LOUEIRE
  • 1997 VAUXHALL CORSA
  • 4 CYL
  • MANUAL
  • 84,000 MILES
I have 1997 corsa, car won't start checked plugs, leads, battery and starter motor, all fine, there is no fuel getting from the pump to the carberetta, help!
Wednesday, February 11th, 2009 AT 5:49 PM
DAVE H
  • 13,384 POSTS
Check the fuel pump fuse in underdash fuse box ! Also the corsa pump has a habit of jamming up. Lift up the back seat. Remove the black round plastic plug you see. Then you will see the pump pipes and wires waggle the wires and tap on the pump a few times. If you have a voltmeter check you have power going to the pump when you turn ignition on and cranking !
Wednesday, February 11th, 2009 AT 7:33 PM
