HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Corsa
Engine
Symptoms
Not Running
1997 Vauxhall Corsa car wont start
LOXY
MEMBER
1997 VAUXHALL CORSA
4 CYL
2WD
MANUAL
70,000 MILES
No spark at the plugs is this a distributor fault
Friday, March 19th, 2010 AT 7:21 AM
MECHANIC
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard
SPONSORED LINKS
Friday, March 19th, 2010 AT 7:24 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Vauxhall Corsa Won't Start,,no Fuel Getting To...
I Have 1997 Corsa, Car Won't Start Checked Plugs, Leads, Battery And Starter Motor, All Fine, There Is No Fuel Getting From The Pump To The...
Asked by
loueire
1 ANSWER
1997
VAUXHALL CORSA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Vauxhall Corsa 1l Turns Over But Wont Start
My Car Has Just Had Its Fuel Tank, Filter, Pump Replaced Aswell As A New Battery. But It Still Wont Start It Turns Over But Wont Start Its...
Asked by
Jolovesdale
2000
VAUXHALL CORSA
Diesel Car Is Turning Over But Will Not Start
Hi, A Guy Managed To Get It Started And He Said It Was A Diesel Relay Or Something. I Bought A New Relay But It's Still Not Starting. Maybe...
Asked by
sessionguitar
2004
VAUXHALL CORSA
2003 Vauxhall Corsa Car Wont Start
2003 Vauxhall Corsa Manual Got Corsa C 53 Plate. Car Wont Start. Had Load Of Sensors Changed, Still No Good. Machanic Told Me...
Asked by
paigehay06
2003
VAUXHALL CORSA
2010 Vauxhall Corsa Car Wont Start
My Car Wont Start. I Have Had The Aa Out And They Said The Alternator Isnt Charging The Battery Passed 10.5 . I Took It To A Garage Had A...
Asked by
kelsey davies
1 ANSWER
2010
VAUXHALL CORSA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
