Truck wont start and kills batery
FAST EDDY69
  • 1993 NISSAN PATHFINDER
  • 145,000 MILES
My truck is in mint condition despite it's age otherwise I wouldn't be wasting your time; problem is that for the last couple of weeks, every now and then while cruising the door locks (all of them) pop up, which causes me to lock them using the control module, and that was fine until I got home last night, next thing in the morning the truck would't start as the battery was dead, well I proceeded to charge the battery and and turn the ignition on only that after letting it run for a while I turned it off, went in the house got a change of clothes got in the truck and voila, the truck not only wouldn't turn on again, but door locks went haywire. Where exactly would the problem be? Thank you in advance for any help you can offer.
Friday, August 9th, 2013 AT 11:20 AM
  • 31,937 POSTS
Sounds like a problem with the central locking control unit, I would see if a scan will pick up any body control unit problems, start here.
Saturday, August 10th, 2013 AT 12:33 AM
FAST EDDY69
  • 7 POSTS
Thank you I''ll get on with it.I know exactly where to look it's inside the right hand side paneling behind the backseat.
Sunday, August 11th, 2013 AT 3:41 AM
FAST EDDY69
  • 7 POSTS
I worked on it this morning and after tussling a bit with the paneling I managed to get it out: I don't have a circuit proof gadget, but opening it looks to me like it can be fixed as long as the shortage source is located. Am I right?
Sunday, August 11th, 2013 AT 9:20 AM
  • 31,937 POSTS
This will depend on what has failed, may be cheaper and quicker to try a known good second hand unit.
Monday, August 12th, 2013 AT 2:48 AM
FAST EDDY69
  • 7 POSTS
The relay blew the coil.I'd better search for another.I forgot to tell you, the alternator was also damaged as a result of the short circuit. Domino effect.
Wednesday, August 14th, 2013 AT 3:21 PM
  • 31,937 POSTS
Did you get it sorted out?
Friday, August 23rd, 2013 AT 3:06 AM
FAST EDDY69
  • 7 POSTS
I replaced the coil with one from an old alarm box and got it to work thanks.
Monday, September 2nd, 2013 AT 5:50 PM
  • 31,937 POSTS
Ok, all good then.
Wednesday, September 4th, 2013 AT 5:02 AM
