1993 Nissan Pathfinder lost power while driving, will not s
JMBARKER82
  • 1993 NISSAN PATHFINDER
  • 6 CYL
  • MANUAL
  • 15,700 MILES
So I was driving home from Boise- about 2.5 hours from my home, and I was about 40 miles from home when I lost power/ rpms, so pulled over to the side and then the Pathfinder completely died on me. I tried to start it again and everything sounded like it wanted to start, but would not start. No clicking, just a grinding of the engine. Or whatever makes the noise as a key turns in the ignition. I am trying to figure out if this may be the alternator, or something else.
Sunday, March 21st, 2010 AT 6:21 PM
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sunday, March 21st, 2010 AT 6:29 PM
