Truck not starting properly
200,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
KATHY BAILEY APPLE
My truck will start right up the first time, but having trouble starting up after i turn it off. I have replaced the fuel pump, starter relay, battery, alternator. what could cause this any ideas? the truck will just turn over but will not start for quite a while then will start.
Dec 28, 2017 at 3:03 AM
CARADIODOC
  • 34,415 POSTS
The clue is in your last sentence. If the engine is cranking normally, the battery, starter and all associated components are okay. The first thing to do is to check for spark when the crank/no-start occurs. You are going to find no spark, no injector pulses, or more commonly, both. This is typically caused by a failing crankshaft position sensor or camshaft position sensor. They often fail by becoming heat-sensitive, then they work again after cooling down for about an hour. While driving, natural air flow keeps the sensors cool, but when a hot engine is stopped, engine heat migrates up to those sensors causing them to fail.
Have the diagnostic fault codes read and recorded too. Those may indicate which circuit needs further diagnosis. The people at most auto parts stores will read fault codes for you for free on 1996 and newer models. You might have to find a mechanic to read codes on older vehicles.
Mar 2, 2021 at 9:50 AM
KATHY BAILEY APPLE
Thank you i replaced the fuel pump it started right up :)
