1995 Ford Ranger stuttered but now won't start
AALDEN5
  • 1995 FORD RANGER
  • 6 CYL
  • MANUAL
  • 228,000 MILES
At first when driven for more than a few miles and proceed to stop and turn off engine. I would have to wait between 30 mins to an hour before she would start. Then soon it became even if I down shifted it would start to stutter and possibly quit. Before I could bleed some air out of the valve on the throttle body. And then she would start back up. Two days ago it finally quit. Replaced fuel pump, fuel filter, checked relay. I know it has fire because it will very momentarily start with starting fluid but soon die
Friday, August 13th, 2010 AT 4:43 PM
Check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Friday, August 13th, 2010 AT 6:25 PM
AALDEN5
There is zero pressure at the throttle body. Just replaced fuel filter, fuel pump.
Saturday, August 14th, 2010 AT 4:21 PM
Just replaced the filter and pump and zero pressure-Do you hear the fuel pump come on-if so check the fuel pressure again-something don't jive here-if not check the fuel pump fuse, relay and inertia swtich
Saturday, August 14th, 2010 AT 4:40 PM
