1995 Ford Ranger
OWENADKINS
  • 1995 FORD RANGER
Engine Mechanical problem
1995 Ford Ranger 6 cyl Four Wheel Drive Manual
I have a 1995 ford ranger, will not having a therostat cause this truck to not start up easy and cause it to miss, I plugged the computer to it and the only code it's throwing is engine cooling temp.
Tuesday, February 23rd, 2010 AT 8:50 PM
  • 109,885 POSTS
The t-stat won't cause it but the temp sensor will. IT is what tells the computer how rich or lean to make the fuel mixture based on coolant temp and ambient temp. You should, however, have a thermostat in the vehicle. The engine needs to run hot enough to be efficient. Without the t-stat, chances are it never truly warms up.
Monday, March 1st, 2010 AT 10:49 PM
OWENADKINS
I just changed the coolant temp sensor and it's still runnin the same the code it's readin is engine coolant temp low cirquit imput, what would u suggest I do now?
Tuesday, March 2nd, 2010 AT 3:23 PM
