1995 Ford Ranger 1995 Ranger WONT START!
TMEFF429
  • 1995 FORD RANGER
  • 4 CYL
  • MANUAL
  • 168,000 MILES
I was coming come from work. I stopped at a stop sign, engine shuts off. All it would do is spin over. Here's what I have done. Dropped the tank checked the fuel pump. Pump is priming. I changed the fuel filter. I took off the fuel line from the outlet of the fuel filter gas shoots out when pump primes. I have changed the fuel pressure regulator, STILL NOTHING. I have checked all the fuses, they're fine. I have been told it is either my computer or the coil pack. Both are not that cheap of a fix just be guessing. PLEASE HELP!
Friday, April 9th, 2010 AT 11:24 PM
RACEFAN966
  • 5,029 POSTS
Ok it could a few different problems but first things first. Pull a plug wire off from the spark plug end and either put an old spark plug in the end or a philips screwdriver and put it near metal (like the valve cover) and crank it over and see if there is spark. Get back to me and we will take it from there.
Saturday, April 10th, 2010 AT 7:50 AM
TMEFF429
  • 14 POSTS
Sorry it took so long to get back to you. I pulled the plug wire and have good spark. What do you want to try next?
Thursday, May 6th, 2010 AT 4:06 PM
TMEFF429
  • 14 POSTS
Do you think it is fuel related?
Friday, May 7th, 2010 AT 9:32 AM
TMEFF429
  • 14 POSTS
I'm gonna try some starter fluid in the throttle body to see if it will try to start up. I guess!
Friday, May 7th, 2010 AT 11:54 PM
TMEFF429
  • 14 POSTS
It would be nice if a Technician would get back to me. I would like to get this truck fixed!
Tuesday, May 11th, 2010 AT 12:15 AM
RACEFAN966
  • 5,029 POSTS
First sorry I didn't get back to you for some reason it didn't repost so I could see that you had responded. With that said I need you to check for fuel. What you need to do is turn the key on then back off. Now on the fuel rail there is a valve remove the cap on that valve then take a small screwdriver and slightly depress the valve (do not look down on it as if there is fuel pressure it will come out with about 40 psi of pressure so keep you face clear) do you get any fuel out of it. It should have around 40 psi. Let me know what you find. If for some reason it don't repost IM me ok.
Thursday, May 13th, 2010 AT 10:36 AM
TMEFF429
  • 14 POSTS
No problem. It took me awhile to get back to you, and for that I'm sorry. I checked the fuel at the rail like you said. I turned the key on, and the fuel pump primed. The only gas that came out ran out like it was coming out of a water hose, and not under pressure.
Thursday, May 13th, 2010 AT 11:26 AM
TMEFF429
  • 14 POSTS
This stupid site will not let you send a private message until you have 10 posts! Go figure!
Friday, May 14th, 2010 AT 12:10 AM
TMEFF429
  • 14 POSTS
Two more times TO GET 10
Friday, May 14th, 2010 AT 12:12 AM
TMEFF429
  • 14 POSTS
Should be 10!
Friday, May 14th, 2010 AT 12:13 AM
RACEFAN966
  • 5,029 POSTS
I don't know why this is being so much trouble to keep in touch sorry. Now with that said do you know what the fuel pressure is? It should be about 40psi. If you could get a fuel pressure tester and check it please so we can determine if it is the fuel pump.
Wednesday, May 19th, 2010 AT 8:56 AM
TMEFF429
  • 14 POSTS
I'll see if I can take care of it this weekend.
Friday, May 21st, 2010 AT 3:48 PM
TMEFF429
  • 14 POSTS
Sorry it took so long my company had me on 12 hours and when I did have time to work on the truck it would rain!
I relieved the fuel pressure( what little there was) hooked up the gauge, and had no pressure. I turned the key on and off 3 more times like the gauge manual said. No pressure. I had replaced the fuel pressure regulator when I replaced the fuel filter. What do you want to do next?
Friday, June 11th, 2010 AT 12:39 PM
RACEFAN966
  • 5,029 POSTS
If you have power to the pump then your fuel pump went bad, and needs to be replaced.
Wednesday, June 16th, 2010 AT 10:08 AM
TMEFF429
  • 14 POSTS
Ok got everything installed still wont start! I have fuel pressure now, but still wont start. I dont know exactly how much pressure, but it shot out of the port on the rail when I checked to see if I pressure. Could it be something in the fuel injection? I dont know.
Wednesday, June 23rd, 2010 AT 8:26 PM
RACEFAN966
  • 5,029 POSTS
Yes it could be injectors but not to common of a problem, so if you would unplug the mass air flow meter and see if it will start and idle. If it does then the mass air flow is bad. Let me know what you find ok.
Friday, June 25th, 2010 AT 9:39 AM
TMEFF429
  • 14 POSTS
Ok unplugged the max air flow sensor, and still nothin. At first it chugged like it was gonna try to start, but didnt. All it does is turn over, and thats it.
Sunday, June 27th, 2010 AT 7:36 AM
