P0732 : GEAR 2 INCORRECT RATIO , which only occurs when 2nd gear is missed or does not engage at all. This has to happen consecutively for it to flag a code. This can be caused by things like stuck valves, electrical issues with commanding the valves, or friction material building up in the transmission. And of course, worst of all, a failing transmission.
First, let's check the transmission fluid. Is it brown / black and smelling burnt? You can try to change the fluid as a potential fix, but it can also adversely affect the transmission if the fluid has never been changed. Can you manually shift the car into 2nd gear, and will it engage and drive? Also, is your scan tool capable of seeing the transmission shift solenoid operation? If so, I would monitor the voltage going to the solenoid while driving to see if the operation is normal.
Please let us know,
William
Oct 11, 2024 at 8:55 AM
