1993 Toyota T-100
JMONSIVAIS
  • 1993 TOYOTA T-100
1993 Toyota T-100
My truck will not start, I have check the started and it's fine and also jumped with cables and still did not turn over, there is a clicking noise only.
Please advise
Saturday, September 25th, 2010 AT 5:38 PM
Is it cranking over and will not start or just won't crank over at all/nothing when you turn key to starting position?
Saturday, September 25th, 2010 AT 5:43 PM
JMONSIVAIS
It does not crank, just clicking noise. Nothing when I turn the key just click click
Saturday, September 25th, 2010 AT 6:25 PM
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Saturday, September 25th, 2010 AT 7:29 PM
