95 Tacoma won't start when hot
JOHNRO
  • 1995 TOYOTA PICKUP
1995 Tacoma 2.4 liter with 170,000 miles won't start when hot and outside temperature is above 85 degrees. This happened last summer but it was worse this year. If I try to start it within 5 minutes after being shutoff it cranks but will not start. I can smell fuel during this time. If the truck sits for 10 or 15 minutes after being shut off it starts every time. I have replaced the distributor and the crank sensor and the problem persists.
Sunday, August 19th, 2007 AT 1:10 PM
Check the fuel pressure, the pump might have a problem holding the pressure they called it residual
Sunday, August 19th, 2007 AT 3:48 PM
