1983 Toyota Pickup Wont Start when cold!
STEWBOMB7
  • 1983 TOYOTA PICKUP
  • 4 CYL
  • 4WD
  • MANUAL
  • 240,000 MILES
I have an 83 toyota pickup, with an 85 rebuilt 22RE in it. Recently when cold it takes forever to fire, about to the point were the battery is dead. Usually I try cranking it and it fires for a short second then dies but if I try it again it wount even fire unless I wait about five min, but each time I wait if fires a little more but wont actually start until doing this for atleast a half hour. Now it wont start or fire period. I bought a new fuel filter knowing ive never replaced that and could be the possilbe problem but can't find were the old filter is actually located. I think it might have been by-passed is that bad? What can I start with?
Saturday, December 29th, 2007 AT 12:31 PM
Is it a Carb or and EFI fuel system?
Saturday, December 29th, 2007 AT 12:37 PM
STEWBOMB7
Its a EFI
Saturday, December 29th, 2007 AT 1:45 PM
Okay understand-open up the air tube at throttle body shoot some carb cleaner in there and attempt to fire it up-did it start? If so fuel problem if not troubleshoot the ignition system.
Also when you turn key to On -do you hear the fuel pump screaming for a few secs if not-check for power. Fuse/relay etc.
Saturday, December 29th, 2007 AT 2:26 PM
