My truck won't start. Started it up went to store. Wouldn't start again. Pull started it. Changed the fuel filter. Then it ran better than it ever has. Drove it, put gas in it, started right up. It sat for 30 min. Or so, went to start it, didn't start. It turns over and smells of gas when turning over. Took spark plug out, put it to ground and turned it over, started right up. Tried the same thing the next day, turned over, but didn't fire. Do you think it's the coil or fuel related or control module?
Thank you!
SPONSORED LINKS
Monday, September 6th, 2010 AT 1:26 PM
