Suspected faulty fuel system
TOYOTA
CHANDAMWAM
Toyota carib manual transmission 4A ENGINE 4wheel drive 1995.
I have changed the fuel pump in the last two weeks and now the fuel filter .
Its like the vehicle is losing power when ascending more especially in gear 2 but no problem in 4.
what could be the reason.
Timing belt was also changed at the same time.
milleage is around 140000 km
pls i need your help.
Aug 8, 2007 at 6:19 PM
[quote:989dd68680="chandamwam"]Toyota carib manual transmission 4A ENGINE 4wheel drive 1995.
pls i need your help.[/quote:989dd68680]
When was it last tuned-up?
When you replaced the pump did you actually check whether its producing the correct pressure.
Could be a restriction in the exhaust system
Aug 14, 2007 at 2:55 AM
