There should be a bolt a the bottom of the tank. open it and get your containers ready to catch the diesel.
if you have an in-tank fuel pump or external electric pump , you might want to disconnect the fuel lines after the pump and turn the ignition on to bleed the diesel out of the lines.
May 22, 2007 at 2:13 AM
