carburetor problem
TOYOTA
STU GALVIN
hi....my carburetor continues to have fuel run through it even when its turned off. If i dont pull the fuel line off, it fills the cylinders up. It is running rough as guts and often stalls when slowing down. It will also surge when backing off the accelerator. It has recently started to ping at the rear which i feel is a small backfire but am not sure?
Jun 6, 2007 at 9:34 PM
  • 75,988 POSTS
[quote:e2bbbf9a5d="stu galvin"]hi....my carburetor continues to have fuel run through it even when its turned off. If i dont pull the fuel line off, it fills the cylinders up. It is running rough as guts and often stalls when slowing down. It will also surge when backing off the accelerator. It has recently started to ping at the rear which i feel is a small backfire but am not sure?[/quote:e2bbbf9a5d]
What are we working on here-you need to follow the help guidance to get a quick answer.
Jun 7, 2007 at 11:40 AM
STU GALVIN
sorry!!.....
it is a 1988 toyota corrolla, 1.6, 360,000km's
Jun 7, 2007 at 8:16 PM
  • 75,988 POSTS
[quote:1db64f6002="stu galvin"]sorry!!.....
it is a 1988 toyota corrolla, 1.6, 360,000km's[/quote:1db64f6002]
Get the Carb rebuild and check the fuel pressure.
Jun 7, 2007 at 11:25 PM
