1991 Other Toyota Models fuel pump
1991 TOYOTA
144,000 MILES • 6 CYL • 4WD • AUTOMATIC
ENGRAVER
no fuel to carb,removed fuel pump and checked it works ok with good pressure.no elect power at the disconnect plug.i don't know where the relays for the pump are located.is there any other reason for my problen.
Jul 18, 2009 at 3:25 AM
  • 75,988 POSTS
Try blocking the flap in the airflow meter and see if it powers up-if not test the circuit opening relay and the airflow meter.
Or this find the check connector jump fp to batt terminal in it-you should have power to the plug. Let me know
Jul 18, 2009 at 1:28 PM
