1994 Toyota Camry Dome Light Not Working
TOYOTA
JESSB_55
  • 8 POSTS
Hi my doom light doesn't work, I've replaced the bulb many times but no luck. It works once in a blue moon but that's all!
Mar 31, 2006 at 5:49 AM
LOSONE
  • 1,616 POSTS
What kind of vehicle and where is the dome light?
Mar 31, 2006 at 5:51 AM
JESSB_55
  • 8 POSTS
it's a 94 Camry and it's located in the center of the ceiling right behind the sunroof.
Mar 31, 2006 at 5:54 AM
LOSONE
  • 1,616 POSTS
It is a simple circuit with 12v on the center of the light socket. When you turn the switch to off it removes the ground. If the sw is on, the ground comes from the door switches.
Take a piece of wire and touch from a ground to the outside of the light socket. If the light lights it is either the ground that the sw uses or the sw. Make sure the bulb fits in the socket tight. If not squeeze the socket without the bulb and replace the bulb.
The ground for that circuit and the 12v comes from Junction Box number one.
Good luck
Mar 31, 2006 at 9:34 AM
Suggested Repair
Confirm the bulb seats tightly; if loose, gently squeeze the empty socket and reinstall the bulb. With the switch on, jump a known ground to the outside of the socket. If the light then works, the fault is the ground path or switch (door switches supply ground). Power and ground for this circuit come from Junction Box number one.
Conversation Summary
A 1994 Toyota Camry dome light behind the sunroof rarely works despite repeated bulb replacements. The expert explained it is a simple 12-volt circuit that is grounded through the switch or door switches, and advised checking socket fit, testing the socket ground, and tracing power and ground to Junction Box number one.
