1991 Toyota Camry Dome Light Door Issue
SAMIDIVE
I replaced the dome light in a 1991 toyota camry because it did not work when the door opens or closes. Even though dome switch is on door, the light only works when the switch is "on" settting. What might be wrong?Car has 115000 mi.
Aug 14, 2006 at 7:56 AM
MIKEYBDMAN
  • 623 POSTS
[quote:30ca031dff="samidive"]I replaced the dome light in a 1991 toyota camry because it did not work when the door opens or closes. Even though dome switch is on door, the light only works when the switch is "on" settting. What might be wrong?Car has 115000 mi.[/quote:30ca031dff]
Looks to be a pretty simple system. When in the door position, if you open either door, it does not turn on the light? If this is the case, then I doubt both door switches have gone bad at the same time. If it only happens with one door or the other, suspect the door switch that doesnt work. If it doesnt work with both doors, then I would suspect the light itself may be bad.
If you have access to a volt ohm meter, then you can remove the doem light and trouble shoot from the plug on the light. You should have power to pin 2 of the plug since the dome works in the on postion. You can check for a ground on pin 1 when your door is open. If you have a ground, then the light itself is bad. If you dont, I would suspect the integration relay. I doubt both door swtiches have gone bad at the same time.
Good luck
Aug 14, 2006 at 8:19 AM
Suggested Repair
If the dome light fails with both doors in the door position, both door switches are unlikely to have failed together. Test the light plug: confirm power at pin 2, then check for ground at pin 1 with a door open. Ground present points to a bad light; no ground points to the integration relay. If only one door fails, suspect that door switch.
Conversation Summary
The owner of a 1991 Toyota Camry with 115,000 miles replaced the dome light, but it still works only in the On position and not when either door opens. The expert says both door switches are unlikely to fail at once. With a meter, confirm power at pin 2 of the light plug and check for ground at pin 1 with a door open; ground means the light is bad, while no ground suggests the integration relay. A single nonworking door points to that door switch.
