1994 Toyota Camry
KRIS BURKETT
  • 1994 TOYOTA CAMRY
Electrical problem
1994 Toyota Camry Two Wheel Drive Automatic 120,00 miles
when I press the brake petal after starting, the lighting icon(outline of car w/dashes,lower left-hand corner) on the dash comes on and stays on from then on while driving. One rear running bulb seams to blow soon after I replace it. Possibly related(???) my dome light blows right away when I replace it. Overall lighting on dash used to go bright and dim,or completely out, until I removed the rear running bulb that blows. since removing it,I haven't noticed the dashboard problem of dimming and brighting.
http://www.2carpros.com/forum/automotive_pictures/447435_Kim__Krisat_the_bar_1.jpg
Im baffaled, anyone???
Saturday, December 12th, 2009 AT 12:44 AM
  • 31,937 POSTS
HI there,
Thank you for the donation,
Have you had the alternator output voltage checked, as the symptoms of the light going bright & dim are one of the signs of a faulty regulator in the alt, this may be an over charging problem, so I feel that we first need to confirm or discount this first.
Mark (mhpautos)
Saturday, December 12th, 2009 AT 4:09 PM
