1997 Toyota Camry Lighter Dead
BABYTAYLORS
I have a 97 toyota camry with about 167000 miles.
The main cigarette lighter wont work when plugging anything into it. I checked all the fuses and can't find a problem with them. What else would make it not work?
Jan 1, 2007 at 9:54 AM
MIKEYBDMAN
  • 623 POSTS
[quote:db87328832="babytaylors"]I have a 97 toyota camry with about 167000 miles.
The main cigarette lighter wont work when plugging anything into it. I checked all the fuses and can't find a problem with them. What else would make it not work?[/quote:db87328832]
This lighter is a pretty simle system. Looks like there is a 15a fuse that supplies power, and it runs to s common ground. If this is the only thing that is not working, then it is probably not the ground. Looks like one or more of the funtions of your clock are powered by the same fuse, so if you clock is working normally, it might just be the lighter itself. I would try and get to the back of the lighter, and check the plug and make sure it is plugged in good. Find someone who has a volt/ohm meter, and check for power on pin 2 and a ground on pin 1. If you have both, then replace the lighter.
If you dont have a ground, then follow the ground wire and see where you loose the ground. If you have no power, check for power at the 15a CIG fuse. Track down the wire between the fuse and lighter to find the break. Could just be a bad lighter.
Have you tried both the lighter and a charger plug?
Jan 1, 2007 at 11:56 AM
M. UTESCH
It is a cigarette lighter itself I had the same issue and now I have the same issue again I burn it out by using electric air pump so I just got to pick a part and get another one from a Camry and install it and Wallah it works
Oct 8, 2019 at 1:52 AM
Thanks for the info. I am sure that info will help others if they have a similar issue.
Oct 8, 2019 at 7:33 AM
Suggested Repair
Confirm the 15A CIG fuse and that the clock (same circuit) works. Check that the lighter connector is seated, with power on pin 2 and ground on pin 1. If both are present, replace the cigarette lighter; high-draw devices such as an electric air pump can burn it out. If power or ground is missing, trace that wire from the fuse or ground point for a break.
Conversation Summary
The owner of a 1997 Toyota Camry with about 167,000 miles said the main cigarette lighter would not power anything and the fuses looked fine. An expert explained the simple fused circuit and shared ground, noted the clock uses the same fuse, and advised checking the rear connector for power and ground, then replacing the lighter or tracing an open wire. Another owner reported the same failure after using an electric air pump and said installing a used Camry lighter fixed it.
