2001 Toyota Camry Electrical problem
131,684 MILES • 4 CYL • 2WD • AUTOMATIC
DLAUBE
Our dash clock and cigarette lighter will not work. I have checked the fuses in the main fuse box under the hood. I have even pulled fuses the check continuity. The manual I have only shows this one fuse panel (under the hood).. Is there another one somewhere else? I've checked under the dash on the driver's side. Is there some type of in line fuse behind the radio?
Dec 25, 2007 at 5:18 AM
  • 75,988 POSTS
Try checking fuse 7.5 in the instrument panel junction box at left of steering column.
Dec 25, 2007 at 6:05 AM
