1989 Toyota Corolla Jerking Misfire
REDRAGON
  • 11 POSTS
toyota corolla 1989 400, 000 k's 1.6 l sedan. when i drive the car for a little while it will heat up and then the problem occurs when i am accelerating with the pedal right down at first it will buck and jerk a little and loose a lot of power and then later on it does it worse and worse and it feels almost like a misfire. i have platinum spark plugs in could it be those ive heard that they are not very good for imports i have cleaned the egr valve the vacuum, i cleaned the fuel pump i have checked the whole ignition system.
Feb 23, 2007 at 11:34 AM
CHEVY22
  • 1,375 POSTS
did you have the problem before the plug install ??? if not i would start there let us know
Feb 23, 2007 at 2:21 PM
  • 75,988 POSTS
[quote:3e0857c134="redragon"]toyota corolla 1989 400, 000 k's 1.6 l sedan. when i drive the car for a little while it will heat up and then the problem occurs when i am accelerating with the pedal right down at first it will buck and jerk a little and loose a lot of power and then later on it does it worse and worse and it feels almost like a misfire. i have platinum spark plugs in could it be those ive heard that they are not very good for imports i have cleaned the egr valve the vacuum, i cleaned the fuel pump i have checked the whole ignition system.[/quote:3e0857c134]
I had a customer back in 2000 w/a coro with them platinums and made it act crazy told him get the OEM,took a 10mins job and the love of God.
Feb 23, 2007 at 3:02 PM
CHEVY22
  • 1,375 POSTS
[quote:0f2e719209="rasmataz"][quote:0f2e719209="redragon"]toyota corolla 1989 400, 000 k's 1.6 l sedan. when i drive the car for a little while it will heat up and then the problem occurs when i am accelerating with the pedal right down at first it will buck and jerk a little and loose a lot of power and then later on it does it worse and worse and it feels almost like a misfire. i have platinum spark plugs in could it be those ive heard that they are not very good for imports i have cleaned the egr valve the vacuum, i cleaned the fuel pump i have checked the whole ignition system.[/quote:0f2e719209]
I had a customer back in 2000 w/a coro with them platinums and made it act crazy told him get the OEM,took a 10mins job and the love of God.[/quote:0f2e719209]
yup the wrong plus will do that , i totally agree
Feb 23, 2007 at 3:08 PM
REDRAGON
  • 11 POSTS
[quote:ec1313c208="redragon"]toyota corolla 1989 400, 000 k's 1.6 l sedan. when i drive the car for a little while it will heat up and then the problem occurs when i am accelerating with the pedal right down at first it will buck and jerk a little and loose a lot of power and then later on it does it worse and worse and it feels almost like a misfire. i have platinum spark plugs in could it be those ive heard that they are not very good for imports i have cleaned the egr valve the vacuum, i cleaned the fuel pump i have checked the whole ignition system.[/quote:ec1313c208]
i dont think i had the problem before that i was also low on oil so the car was probly heading up the plugs very quickly im gonna change them tomrow c what happens :)
Feb 23, 2007 at 6:16 PM
Suggested Repair
Replace the platinum spark plugs with the correct OEM plugs for the 1989 Toyota Corolla, then retest under hard acceleration after the engine is fully hot.
Conversation Summary
The owner of a high-mileage 1989 Toyota Corolla 1.6L reported bucking, jerking, power loss, and a misfire-like feel during hard acceleration after the engine warmed up. The owner had cleaned the EGR valve, vacuum lines, and fuel pump and checked the ignition system, but suspected the platinum plugs and noted the engine had been low on oil. Experts agreed that incorrect platinum plugs can cause this behavior and recommended installing OEM plugs.
