1993 Toyota Corolla Cold Start Sputter
TOYOTAH
I went out to start my moms car this morning ,and all it would do is spit and sputter.
It would start some times ,and idle for a few seconds then sputter and quit.
It also would roll over hard sometimes ,and then roll over fine a few seconds later.
I would like to know what would cause that ,as this is the first time we've had it happen.
This is what I know about the car it's a 1993 toyota corolla 4wd .
The engine model is 4A-FE ,and it has been using a litre of oil every 2-3 weeks.
We use 5 W-30 synthetic oil in the engine.
It has also been losing antifreeze ,but I just found a lose hose clamp on the top rad hose today.
I figure that might be where the antifreeze was going ,as it had a few drops of antifreeze coming from the loose hose.
I don't want to rule out that it might be a engine symptom though.
Any help would be nice thanks
About an half hour after posting this the car started fine like nothing was wrong, but I still would like to know what would cause it to not start earlier this morning?
I forgot to put that it was about -15 to -20 but I had it plugged in ,so maybe it could be that .
But it starts in weather like that all winter long if not colder?
Feb 18, 2007 at 6:57 AM
  • 75,988 POSTS
[quote:96b700b8a9="toyotah"]I went out to start my moms car this morning ,and all it would do is spit and sputter.
But it starts in weather like that all winter long if not colder?[/quote:96b700b8a9]
Check your coolant temperature sensor and IACV
Feb 18, 2007 at 9:03 PM
TOYOTAH
ok I will thanks
Feb 19, 2007 at 8:08 AM
Suggested Repair
Check the coolant temperature sensor and the idle air control valve (IACV).
Conversation Summary
A 1993 Toyota Corolla 4WD with a 4A-FE engine spit, sputtered, stalled after brief idle, and sometimes cranked hard in very cold weather, then started normally later. The owner also noted oil use and a loose upper radiator hose clamp with minor coolant leakage. The expert recommended checking the coolant temperature sensor and IACV.
